Weird oil pressure....Help Please
1998 LS1 with all bolt ons, ported heads, cam, and slp oil pump. done at Speed Inc.
all of a sudden at idle I have no oil pressure, i can rev the engine and get it to go up to 40-50 or somethin. and then it will drop back down slowly. The SLP oil pump was put on by speed inc in '04 at approximatly 80k. car now has a bit over 100k on it now.
I would appreciate all input, I think Ill take the pan off and check things out....
HELP PLEASE!!!!!!!!!!!!!!!!!!!!!!
I have no idea what im looking for to take the oil sending unit off so i can test the oil pressure. is there a possibility of a spun bearing with 100k miles and a cam??
ruined all my weekend plans...
There is always the possibility of a spun bearing, but the noise would seem to come from the bottom end. There are two ways, that I know of to hook up a mech. gauge. Either from the sending unit, behind the intake manifold, under the cowl. Or right above the oil filter there is a hook up point, You could also remove your stock sending unit and, with a mirror, check for oil flow with the engine running.
