When torquing heads with ARP studs.......
Old Apr 26, 2003 | 07:08 PM
StevieZ's Avatar
Default When torquing heads with ARP studs.......
Do you apply assembly lube just on the underside of the nut or do you put some on the threads too?
Old Apr 26, 2003 | 08:26 PM
Slowhawk's Avatar
LS1Tech Sponsor
Default Re: When torquing heads with ARP studs.......
Put the assembly lube on both sides of the washer and on the threads or bolt threads.
Old Apr 27, 2003 | 09:48 AM
Damian's Avatar
LSX Mechanic
I bought my studs used and they didn't come with the assembly lube. I just used loctite on the threads that go into the block, and nothing on the other side. No problems for me...
Josh
