Dealer re-using old head bolts
They crack-up and say you are only making GM rich.
Is this possible?
The head, main, and rod bolts are not re-usable, as noted by GM, and is non-negotiable.
I checked with a licensed structural engineer who advises NY on highway bridge construction. He concludes all bolts stretch too.
I used new bolts but if I ever ripp the heads off again, I'm not sure I would buy new bolts again???
You have to step back and think about what a bolt actual does, mechanically, for your engine. Why do people use rod bolt stretch gauges insead of just torquing to a specific ftlbs rating? Because the torque spec in ftlbs is an approximation of how much force/torque it takes to stretch that bolt so far, which is what what happens when you are providing that clamping force.
Next time, ask a mechanical engineer...this is more up their allies!
800-456-0211 / PM / Facebook
WHIPPLE Superchargers, Procharger, Magnuson, Powerbond Sale, HPTuners packages!, Trickflow, AFR, PRC, CHE Trunion upgrade, $100 7.400" pushrod set, Custom Cam of your choice
Matt:
I thought a torque wrench would give you a good idea of how much torque a given bolt (new or old) will be applying to the head? I realize TTY bolts are installed without a torque wrench, but is this necessary?
In other words, lets say you used new TTY bolts and wrenched them to 75lbs. Would that get you close to the factory tollerence?
That's an article from our friends at Oliver that might help clear some of this up!!
ex ls1 heads require NEW bolts to be torqued in sequence at 37 lb/ft. Then each bolt is tighened an aditional 120º of rotation to add the correct stretch
if a mechanic had to do a head job under warranty, why wouldnt they get the damn bolts, its not like its coming out of the mechanics pocket.
No one at my dealer would ever reuse TTY bolts, Especially under warranty.
we must have some cheap *** service managers in my area. My instructor was a mechanic for7 years. People would come in under warrenty complaining of squeaking brakes.
Break off the squealer. Done.
I think they would reuse bolts SPECIFICALLY if it was under warranty.
