priming engine after 4 years not used
when i put oilpressure in here, it will go through the filter prior to entering the engine ??
please don't tell me to just start the engine without sparkplugs or anything, i WANT to put oil pressure in it prior to startup ....
pull out the plug and if you see oil, then you are in the oil galley. the only problem you may encounter is that if you pressurize that area, the oil may just follow the path of least resistance and go towards the pump and the oil pan, doing nothing to lube the rest of the motor
just pull the plugs and fuel pump fuse so it can spin freely with little resistance (compression)
I have one of these...http://www.motiveproducts.com/02bleeders.html
and am going to modify the end with the fitting for the oil galley.
I also have a valve so I can pressurize the unit to 20 psi and crack it open and watch for oil @ the top of the motor.
Should work and is cheaper too.
thanks, thats usefull info
if i was 100% sure the engine would start right up after a couple of turns,
and it had only been a short while after it ran ..... i might.
but it's a complete transplant into a 70's non gm body, and the chance for it to start right off , isn't 100%
i never do a transplant without a engine prelube......
Jeejee
Ben T.
