View Poll Results: Patriot 226 cam vs. TFS Stage 3 cam
Patriot 226 cam
![](https://ls1tech.com/forums/images/polls/bar2-l.gif)
![](https://ls1tech.com/forums/images/polls/bar2.gif)
![](https://ls1tech.com/forums/images/polls/bar2-r.gif)
![](https://ls1tech.com/forums/clear.gif)
30
40.54%
TFS Stage 3 cam
![](https://ls1tech.com/forums/images/polls/bar3-l.gif)
![](https://ls1tech.com/forums/images/polls/bar3.gif)
![](https://ls1tech.com/forums/images/polls/bar3-r.gif)
44
59.46%
Voters: 74. You may not vote on this poll
Patriot 226 vs Trick Flow Stage 3
#63
The T2 really lacked the bottom end I was looking for, didn't really perform til 4k & was sometimes a pain in stop & go traffic.. The TFSIII feels great everywhere, just as good up top as the T2 & drivability isn't an issue.
#64
Thanks for the info. People have suggested the T2 but I want the power a little lower, more streetable. I was thinking the new Patriot 225/229 .580"/.590" 114° or the comp 224/230 .581/.588 114°.
The TFS III is 228 int./230 exh. 0.585 int./0.585 exh. lift 112° LSA correct?
#66
Ive looked at this cam before and have considered it. I want to go bigger than my 224cam,but not loose alot down low.What do you put down with your combo now? I'm an A4 and put down 417rwhp 407rwt,with tsp 5.3 heads tr224/112 and ported 90/90 ,just looking for more power,but not loose too much down low
#69
#74
I am going ot have to disagree with a camswap being atleast 1000 bucks..
From what I understand, Hydraulic Cams are pretty much good for a long time, unless its scared up or whatnot,.
So used cam - 200 bucks
Pushrods - 70 bucks
918's- 150
Gasket Set and bolt- 100 bucks
thats only 520 bucks... and thats everything..... (Assuming you do labor yourself, but camswaps around here run about 200-250, but a side jobber)
So 720 installed... Thats a lot better than 1000 before labor...
Pushrods - 70 bucks
918's- 150
#75
Pushrods - 70 bucks
918's- 150
Pushrods - 70 bucks
918's- 150
By the way, did the OP ever get that Patrick G custom cam installed? No results posted?
