trickflow 215's and 242/248 .610/.615-110 comp
anyone have a idea what this combo will produce in power and 1/4 wise? i am running a forged 347 with 6.125 h-beam rods, diamond -2cc pistons, and a comp 242/248 .610/.615-110 cam. i will be ordering a fast 90/90 and the trickflow heads friday, so the mod list will be as follows, forged 347, trickflow heads with roller rockers, fast 90/90, hooker 1 3/4 headers into true duals with dumps, 60lb injectors and dual 255 intank pumps (currently run dual dry nitrous, car is dailed in and idles and drives fine with the cam and injectors now) as for drivetrain it consists of a th400 with transbrake and a 3600 stall (tight for nitrous) and outback i run a ford 9 inch with 35 spline axles with 4.30's and a spool. will change the gear if i decide to play on nitrous as i am sure i will run out of gearing. currently the car weighs 3740 with me in it, any input will be appreciated. thanks guys
depends on how much i have the heads milled, thinking around 11.5 to 1, need some input on what would be best. i would like to stick to pump gas but would like the most from this combo so i am open to suggestions cause i want to get it right the first time. its mainly a weekend toy, only drive it around to play.
