ls1 vs 6.0 L block?more hp???
what block is better for more hp and stronger results? going with stock internals only forged stock bore and crank? going to use some nitrous, head- cam- ported heads, ls6 intake ect ect.?? what do you guys think?
Stock vs. Stock Cubes..the 6.0l is goin to get it. If you bore/stroke it up.. I think that the Iron Block will handle more power, expecially if you are spraying.
I got a friend that put a stock internal LQ9 with a MS3 Cam into his Z28, he said it was a world of difference between the LS1 that was in there with the same Cam.
