Squeeling/tapping in valvetrain
The other day I started getting a squealing noise in my passenger side valvetrain. I relashed all the valves but it's still there. I also noticed it's tapping alot more. Everything seemed normal when I was in there. I plan to pull the rockers and go from there. Is there anything I should be looking for or something that could cause this?
It comes and goes with rpm's if that makes sense. The higher the rpm the more frequent and quicker the noise is....almost like something rubbing. When it first started it only did it when the car was up to temp. Now it's all the time.
Your describing it like more of a rubbing. Then i would say more along the lines of accesory drive (alti, idler, p.s.)?? sounds can be decieving. Try a dab a grease on the belt. I have heard belt glaze make a tap/rub noise.
