427ci head gasket question...
Old May 28, 2007 | 02:57 PM
Black2001z06's Avatar
Default 427ci head gasket question...
I am going to be replacing the head gaskets on my MTI 427ci motor.
The block is a ls1 Darton resleeved block, 4.125 bore.
My question is will these gaskets work with this block?
Cometic MLS Cylinder Head Gasket, LS1 Darton Sleeved Engine,
.040 thickness, 4.165 bore
I read on MTI's website that "custom" cosmetic gaskets are required.
Do I need a 4.130 bore gasket, or a different thickness?
Any help would be appreciated.
Thanks,
Old May 28, 2007 | 11:19 PM
silent1's Avatar
They'll work. I'm running those on my 427 Darton block right now without issues.
Old May 28, 2007 | 11:22 PM
1936FordPU's Avatar
Thanks,
Is that really the issues Justin? If so, thats a good relief!
Old May 29, 2007 | 03:28 PM
Thank you guys!
I pray it is only a head gasket, and not a leaking sleeve!
We are running a coolant pressure test and a leak down test to hopefully clue us in.
