120K and Cylinder walls still have Cross Hatchings?
While doing the H/C swap for my car I noticed that the cylinder walls still had cross hatchings along all of them. Is this normal? Isnt this the sign of 'newer' engine?
I am wondering if my car ever had a swap done to it previously ... it did dyno 308/328 with 117K on the ODO.
Ill Post a pic later on.
Could be that whom ever owned it before you was using very good synthetic oil from a very early point in the engines life. I remember reading a story on another forum on how ford ran 2 of their 3.0 Duratec V6's for 100,000 miles one using dino oil from the start and the other synthetic. At the 100 thousand mark they tour the engines down and the one using synthetic still had the hash marks from the hone. Usually you won't see this because a proper break in period taken with normal dino oil will be enough to give the walls a slight mirror finish but in this case because no break in was taken with regular oil the walls were hardly worn at all.
I thought this video was an interesting test for Mobil 1.....
http://www.mobiloil.com/USA-English/...Las_Vegas.aspx
The LT1s were the same way, some showd crosshatch a 200K even from what i remember! I believe a big part of it is teh precision to which teh machining is done these days. The synthetic deffinatly helps though!
Every LT1 and newer GM engine I've torn down (LS1's, LT1's, LS6's, LQ4's) have ALL had the cross hatches, some as high as 180K miles on them. It's a product of high surface finish tolerances in production combined with low tension rings and really good PCM's (good fuel management). Engines don't get old as fast as they used to.
