GM Racing cnc LS6 head oddities
Old Jan 29, 2003 | 08:54 PM
Gold Z's Avatar
Default GM Racing cnc LS6 head oddities
I just receive a set of GM Racing CNC LS6 heads, part #88958622. While they do have the lightweight hollow stem valves and the sodium-potassium filled exhaust valves, the valves are the standard LS1 valve length. Aren't the 2002 LS6 valves supposed to be 6mm, or .236", longer than an LS1 valve? Also, the valve springs are not yellow like a standard 2002 LS6 spring but rather have a green anodized finish. The spec card showed the max lift to be .570". Are these the standard spring colored differently or an entirely different spring? FWIW, the cnc job is pretty rough. At a minimum you could not run these heads without cleaning up the combustion chamber, especially around the treads of the sparkplug hole as they are very sharp and jagged
Old Jan 29, 2003 | 09:11 PM
Gary Z's Avatar
Default Re: GM Racing cnc LS6 head oddities
The '02 LS6 valves are 0.6 mm longer than LS1 valves.
<small>[ January 29, 2003, 09:12 PM: Message edited by: Gary Z ]</small>
Old Jan 29, 2003 | 09:17 PM
Jay 95WS6's Avatar
the ones i got 3 months ago had 02 LS6 (yellow) springs on them
Jay
Old Jan 29, 2003 | 09:18 PM
Gold Z's Avatar
Thanks, Gary. That decimal place I missed explains a lot.
Old Jan 30, 2003 | 09:49 AM
white2001s10's Avatar
Gold Z, how much did those cost may I ask?
Old Jan 30, 2003 | 02:47 PM
Gold Z's Avatar
I bought them from Scoggin-Dickey http://www.sdpc2000.com/default.htm $1970 per pair plus shipping. Also, there is no core charge. You get to keep your heads.
