Proper pushrod length
Old Jun 1, 2007 | 07:15 AM
blu1's Avatar
Default Proper pushrod length
Well i finally decided on my setup and will be placing the order once I receive a call back from Texas Speed. For some reason every time I call I get the office is closed message no matter what time it is.
Basically I will be ordering the following and want to make sure I order the proper length to make valvetrain noise minimal.
TSP 5.3L stage 2.5 heads 62.5-63cc
Torquer V3 on a 111lsa
can't decide between caddy lifters and LS7 lifters
Is that all the info needed for the gurus to make a recommendation? Ive read I will be fine with the stock 7.4 but I've also heard 7.425 will work better. I just want to get it right the first time. I will be running stock MLS headgaskets also.
Old Jun 1, 2007 | 04:51 PM
BAD2000TA's Avatar
Get a pushrod checker. It's cheap and takes the guess work out before buying the wrong length.
Old Jun 1, 2007 | 05:17 PM
91 LS1 Z28's Avatar
^ +1, I agree. Nothing better then knowing for sure when assembling your motor instead of just guessing.
Old Jun 1, 2007 | 05:25 PM
vettenuts's Avatar
+2, when you measure and order pushrods you will get them quickly. I ordered mine from Summit and got them in two days while I worked on another part of the motor. Just plan accordingly.
