Milling
Old May 1, 2003 | 09:55 PM
LS1 Brent's Avatar
Default Milling
What does it mean to mill the heads .15??
Old May 1, 2003 | 09:57 PM
89ws6formula50's Avatar
Default Re: Milling
Its how much the machine shop is taking off the bottom of the head, the side that mates with the top of the cylinder block. It is done to increase your compression ration, BUT, you must beware if using an aftermarket cam that the lift is not too much as to make the valves hit the tops of the pistons because milling brings the valves closer to the tops of the pistons.
Old May 2, 2003 | 03:04 PM
robertbartsch's Avatar
Default Re: Milling
I don't think you can mill heads .15... Do you mean .015?
Old May 2, 2003 | 04:11 PM
LS1 Brent's Avatar
Default Re: Milling
yes i do mean .015
