Cammed LS1 needs heads. Suggestions please.
Old Jun 7, 2007 | 07:55 PM
Local-heretic's Avatar
Thank you for all the suggestions everyone. I'll look at the codes on my door tomorrow to let you know my gears.
RedDemonLSX, your car vs mine= very interesting race...
Old Jun 7, 2007 | 07:59 PM
damn double posts...
Old Jun 7, 2007 | 08:45 PM
will82's Avatar
From: Somewhere Between Mild Insanity and Complete Psychosis
cool.
I might want to ride in your car at the next meet. looking to get a stall soon, not sure how big i can go and still feel tight enough for my taste.
Old Jun 7, 2007 | 09:13 PM
CaliboyTA's Avatar
i say with that 3ks u have, buy urself a 9 inch or a 12 bolt. doesn't matter how much power u have, a blown rear end wont get u anywhere. lol thats y im stuck at home . to stick to the topic either tfs, afr, etp.
Old Jun 7, 2007 | 10:04 PM
Originally Posted by will82
cool.
You're more than welcomed to ride bro.
Old Jun 7, 2007 | 10:05 PM
A 12 bolt is in the plans, but not yet. Heads is my next step.
Old Jun 8, 2007 | 04:21 PM
Usually I'd say what the others are saying: AFR 205 or TFS 215. Actually I'd scream it at the top of my lungs not to go with stock casting heads, however, a high-stalled auto is the one exception. If it were my car, I'd save the $$$ for something else and go with some TSP PRC LS6 heads.
Usually I wouldn't recommend them over AFR 205 or TFS 215, but where those heads really earn the salt is their flow velocity through smaller intake runners. They really shine over stock casting ported heads in the lower rpms b/c of their low end torque/throttle response. Up top they are still better, but the margin is much closer. Sinve you have a high-stalled a4, throttle response and oommph down low ain't gonna be an issue.
Save that extra $1000 + towards the rear and get both heads and a rear! Or a ported FAST setup?
BTW, what rear ratio are you running right now?
I have the GU5 code = 3.23's
My car has the LS6 intake. Is the FAST setup HP/TQ gain worth the money in your opinion?
Old Jun 8, 2007 | 04:32 PM
will82's Avatar
That's very subjective. It will gain power, but it will cost $1000. 10-15 gains are reasonable to expect from what I have seen. If the f-body rears are as weak as everyone says they are, I'd take care of that first.
Old Jun 8, 2007 | 04:33 PM
will82's Avatar
3.23 is a good ratio for an a4. I have 2.73 so a stall will be looser with mine, but I could at least get an idea. Plus I'm not going as big as a 3500.
