How to install lifters?
Old Jun 6, 2007 | 10:46 PM
Superjoe's Avatar
Default How to install lifters?
I'm upgrading the lifters in my '00 WS6 to LS7 lifters and I want to make sure I know what I'm doing when they get here.
All you have to do is soak them in oil overnight and then drop them in the place of the originals right? There's no adjustments to make?
Thanks!
Old Jun 6, 2007 | 10:49 PM
sidewayz28's Avatar
exacto
Old Jun 6, 2007 | 10:59 PM
Superjoe's Avatar
Sweet, thanks!
Old Jun 6, 2007 | 11:10 PM
sidewayz28's Avatar
yup, i was a fool and thought i got the wrong lifters.. lol thought they didnt fit, but my patience level was running pretty low that day good luck with the install
Old Jun 7, 2007 | 08:02 AM
GuitsBoy's Avatar
Yeah, its pretty self evident once you get in there. Just pop out the lifter retainer, remove the lifters, plug new lifters into the retainers and reinsert into the block. dont forget to loctite the retainer bolt. The oiling hole does not matter which way it faces, so the lifters ont have to be oriented one way or the other. Also, you can get some new LS2 lifter retainers for very cheap for added piece of mind.
Old Jun 7, 2007 | 12:26 PM
ROCNDAV's Avatar
Whats sifferent about the LS2 lifter retainer? Do you have the PN?
Old Jun 7, 2007 | 01:08 PM
PREDATOR-Z's Avatar
1- VERY IMPORTANT- Clean the lifters in mineral spirit before you presoak
2- Only presoak for 2>3 hours before install in a very lightweight oil (not thick), like Dyno oil.
I prefer the oil holes facing galley (personal preference)
Old Jun 7, 2007 | 02:04 PM
ROCNDAV's Avatar
You mean "wipe the outside of the lifters with a mineral spirit soaked rag/towel" correct? so people don't misunderstand and soak their lifters in some kind of solvent. right?
THat's what I was planning, just some regular old white bottle Castrol Dino oil.
same here.
 Michael S. Palmer
Old Jun 7, 2007 | 02:38 PM
PREDATOR-Z's Avatar
Yes but I actually take a tooth brush and dip in solvent, clean thoroughly in the cup and especialy roller area.
Then dry with a compressed air and soak directly after that.
Old Jun 7, 2007 | 02:53 PM
Mike94ZLT1's Avatar
Aww dammit I didn't do that, theyre still soaking in oil though. Should I pull em out and clean them off or what? They've been soaking in rotella for over a month.
Old Jun 7, 2007 | 03:08 PM
PREDATOR-Z's Avatar
Lifter Aquarium?
Yeah, I would clean them and resoak for 2 hours prior to install. The coating they use to protect them is not really oil soluble, that is why they recommend to clean before soaking.
Old Jun 7, 2007 | 03:40 PM
ROCNDAV's Avatar
I have you beat! My brand new stock LS1 lifters have been soaking in oil since March. Now, Im not even going to use them, as I got these new caddy lifters.
Old Jun 7, 2007 | 04:10 PM
voda1's Avatar
Difference anyone?
Old Jun 7, 2007 | 06:13 PM
bigdsz's Avatar
My Caddy lifters have been soaking since January. My new 408 Erik built for me is being delivered tomorrow afternoon.
Old Jun 7, 2007 | 06:35 PM
dyls1's Avatar
Just curious about only presoaking the lifters for an hour or two. Does it hurt anything to do it longer?
Old Jun 7, 2007 | 08:14 PM
Superjoe's Avatar
No way. Two hours is just a safe minimum. Also consider how long it's going to take to assemble the rest of the engine, they're going to be draining the whole time. I don't see how it could hurt to have left them in there longer.
Old Jun 8, 2007 | 12:25 AM
PREDATOR-Z's Avatar
It doesnt hurt, but you have to clean them BEFORE soaking.
Old Jun 8, 2007 | 01:54 AM
santiago's Avatar
what exactly and where do you get this solvent?
Old Jun 8, 2007 | 08:24 AM
Superjoe's Avatar
I am just going to clean mine in rubbing alcohol before I soak them.
Old Jun 8, 2007 | 11:24 AM
ROCNDAV's Avatar
I would say WD-40 would also work good with a toothbrush.
