Does anyone see a problem with this set of heads on this cam? Plese help out
1.5 TEA Ported 5.3 Heads
PRC Gold Dual Valve Springs & Retainers
Milled to 59 CC
Stock Valves
and the cam is an HPE S cam, specs are
238/242 .608/.612 113lsa
From the number it looks close but, I would rather get your opinion before I pull the trigger!!
Thanks for any help
Roger
Then your gonna have to worry abotu the SCR & DCR with the heads milled that much & the higher compression. Then also don't forget about the quench area with whatever gasket you go with.
It starts gettin more technical when you start milling & adding compression on pump gas.
Adding extra head gasket thickness is not something I'd personally do or advise in doin.
