Rod Bolt Failure
Old Jun 9, 2007 | 07:59 AM
Treed Ya's Avatar
Default Rod Bolt Failure
Through reading and speaking with several reputable tuners, I am beginning to wonder if the rod bolt failure thing is a myth. The older design rod bolts were indeed a weak link, but the later design on the ls1/ls6 dosen't seem to be a problem. I see everyone jumping on the bandwagon and saying change your rod bolts.
So if you have indeed had a rod bolt failure on the later design rod bolt lets hear about it. If you have abused your stock bottom end with stock rod bolts lets hear about it too.
Maybe include RPM's turned, what power, what power adder, and at how many miles they let go or haven't let go.
Old Jun 9, 2007 | 09:09 AM
john563's Avatar
Good idea.I have a98 and wondered the same thing.Ive seen guys in 98 with stock rodbolts and abig cam do fine
Old Jun 9, 2007 | 09:38 AM
allngn_c5's Avatar
I have a 2000 FRC (see SIG) Rev limiter set at 6800 So good so far.
Old Jun 9, 2007 | 10:51 AM
purdueranger's Avatar
X4 sees 6500-6800, once it hit 7000 but I try to keep her and shift at 6700 RPMs. Stock rod bolts and almost 90k on the bottom end.
Old Jun 9, 2007 | 11:01 AM
Jantzer98SS's Avatar
98 with 500+ 1/4 passes, 200+ in the low 11's high 10's, stock shortblock, 6800-7000 rpm shifts. Never a problem.
The motor is out, and has katech's in now.
Old Jun 9, 2007 | 02:49 PM
Treed Ya's Avatar
bump ttt
Old Jun 9, 2007 | 02:54 PM
sstony's Avatar
when did they change rod bolt design in the LS1??
tee-boy's Avatar
Default good topic
I often think this is less of a myth and more of hype to sell rod bolts. I often wonder the same thing about the weakness of the 10 bolt.
Old Jun 9, 2007 | 03:47 PM
james562's Avatar
They changed the design in the middle of 2000
I still see plenty of 98-99's with big cams and high shift points (6800+) but they may be on borrowed time
Old Jun 9, 2007 | 04:06 PM
Hocky's Avatar
On my 2002 motor, I saw 7200rpm on a monster cam and 200+ shot every day for 2 years. When it finally came apart, it seems as if the rod stretched itself apart from rpm.... all rod bolts were intact.
Old Jun 9, 2007 | 05:32 PM
Phillymu's Avatar
99 TA MS4 seen 7k plenty of times. Still ok here
Old Jun 9, 2007 | 06:08 PM
Thule's Avatar
i heard this about the 98 bolts, and changed to katech bolts, the crank rod bearing was wpuned as hell.. (sao i belive that romour) but the rod bolt was fine
Old Jun 9, 2007 | 06:53 PM
deeloc1's Avatar
is that 200+ N20 with stock pistons?
Old Jun 9, 2007 | 06:55 PM
deeloc1's Avatar
were you using stock pistons for the 200+ shot?...curious because i want to know my limits...i have a 2002 ls1 out of a SS.
Old Jun 9, 2007 | 07:33 PM
Hocky's Avatar
I was up to a 275 shot on the stock pistons, didn't hurt them a bit.
Old Jun 9, 2007 | 07:41 PM
deeloc1's Avatar
Daaaaaaaaaaaaaamn! you've got nuts...you must have had a tune out of this world! where you running a ls6 or fast? i'm thinking with a 275 shot you probably used the carb intake or a sheet metal intake??? What n2o set up were you running and how big was the cam you were using?...i'm interested to know how much rwhp/tq you were running with?!
Old Jun 9, 2007 | 07:47 PM
ls1muscle's Avatar
I forsee 1-2 blown motors in the next couple of days
Old Jun 9, 2007 | 08:00 PM
john563's Avatar
And Im worried about doing a 100 shot on my heads and cam set up on a stock bottom Im not that brave.Ill stick with a 75-100 till i forge it
Old Jun 9, 2007 | 08:03 PM
Hocky's Avatar
I was running an LS6 manifold. The nitrous kit was pieced together from all over, but it was a single nozzle wet set up. I was flowing it all through the intake mani without problems, but I was using a progressive controller to keep the hit soft. I have no dyno numbers, I do all of my tuning (and most of my playing) on the street. My car did trap 138mph on a 150 hit and ran dead even with a car that went 144 on 200 with a ~3000lb race weight. It was doing ok. Never saw any track time on the bigger shots. It finally came apart around 7krpm in 4th gear one night on a motor only pull. Never really had any detonation problems, did everything on pump gas. Burned one plug, but that is as bad as it was until what I have to assume was rpm finally killed the motor.
Old Jun 10, 2007 | 10:30 AM
david vericker's Avatar
GMPP does recommend that the rod bolts be upgraded on the early model LS1 motors that exceeded 450 crank HP. Knowing that GM made this request to it's customers, then I would have to say that the concern was (is) valid and not a myth.
However, I do agree with you that the later model (upgraded) rod bolts do have the ability to handle a lot more HP without failure. I would like to know the the PSI specification of the old rod bolts vs the upgraded version - I bet there is a considerabe difference in the two.
