MS4, Trex, Ridiculously large
Old Jun 12, 2007 | 02:11 PM
blueeyeddevil141's Avatar
Originally Posted by lilbuddy1587
245/250 .611/.615 110+1 would be suicide without flycutting.......
Hahaha. I am leaning heavily at MS4....
Old Jun 12, 2007 | 02:12 PM
sciff5's Avatar
The guy running it hasnt flycut his pistons and hes been running it perfectly fine...
It was designed to be run without flycutting. I already talked to chummmma about this
btw the reason I dont want to flycut my pistons is because of the added cost of doing so.
If I am correct its a few hundred bucks to get a shop to flycut the pistons
Old Jun 12, 2007 | 02:18 PM
GT Griller's Avatar
Question : do those cams fit without flycutting ?
Answer : Yes
Old Jun 12, 2007 | 02:19 PM
sciff5's Avatar
Answer : Yes
What was the point of this post??
Old Jun 12, 2007 | 03:36 PM
Okay I am thinking the MS4 on the 111, how's everyone feel about this?
Old Jun 12, 2007 | 03:57 PM
GT Griller's Avatar
To answer the damn question....lol
Yea MS4 is a pretty badass cam my buddy had it in his A4 camaro with a 3800 stall.....u said u got a 3500 ur gonna need a bit more even my buddies 3800 left a dead spot.
Old Jun 12, 2007 | 04:04 PM
Mcduffys's Avatar
So a few hundred bucks isnt worth it? I guess you could have some PTV issues, kiss a couple valves to pistons and have it cost you a motor.
I vote the for X4 if you really dont want to fly cut.
Old Jun 12, 2007 | 10:26 PM
CamaroSS's Avatar
I gained .2 just from swapping a Yank SS4000 for a Yank PE4400. So your car will enjoy a bigger converter.
It's hard for me to choose between Texas Speed and Thunder Racing since they are the 2 main places I buy my parts from, but I ended up choosing the TRex. I felt it was the safe choice to go with, and it was putting out great numbers. I was also deterred by the larger lift specs on the MS4, I felt it may lead to premature springs issues or the need to be changed sooner.
 Michael S. Palmer
Old Jun 12, 2007 | 10:32 PM
Z28_DAD's Avatar
Old Jun 12, 2007 | 11:15 PM
sciff5's Avatar
Originally Posted by Z28_DAD
I was referring to the guy whos post I was quoting, I thought it was pointless.. because its well known that all the cams mentioned can be run without flycutting.
Old Jun 12, 2007 | 11:19 PM
lilbuddy1587's Avatar
That is assinine...The duration and LSA WITH advance still allows it to "safely" fit under stock heads? BULL ****!
Old Jun 12, 2007 | 11:37 PM
  #32
I am still thinking MS4 ahah. If the verter is horrible I will eventually upgrade.
Old Jun 13, 2007 | 09:27 AM
  #33
Jon@Texas-Speed's Avatar
The MS4 will clear with enough PTV clearance so that flycutting won't be a concern. It has way more PTV than some of the other big cams out there. We have installed it on several cars using stock heads without an issue. Put it in our cam package with the PRC Dual Springs and chromoly pushrods and your valvetrain should be ready to go! If you have any questions at all, feel free to give us a call or shoot us a PM.
Old Jun 13, 2007 | 04:11 PM
  #34
I gave you a call already! And I am sticking with my choice of the MS4. Since I have 120k do I need new lifters? No, right?
Old Jun 13, 2007 | 07:02 PM
  #35
CamaroSS's Avatar
Well there you all go!
It's all about when and where the valve events occur. You could have a .550 lift cam hit the piston if it begins to open faster than the piston leaves TDC. You want the valve to safely follow the piston.
Old Jun 13, 2007 | 07:35 PM
  #36
GT Griller's Avatar
naw u shouldnt but i would get new seats and seals.
Old Jun 14, 2007 | 12:48 AM
  #37
How much of a pain in the *** are seats/seals to put in? I have to change my springs, so should I pull my heads or do them in car?
Old Jun 14, 2007 | 12:51 AM
  #38
GT Griller's Avatar
do them in the car......that come right out once u take the stock springs off.....pull the seal then the seat, then reverse the order to go back in.
