cam install???
Old Jun 12, 2007 | 07:34 PM
jares99's Avatar
Default cam install???
when I go to install my cam and springs would it be worth it just to remove the headsto change the springs, or will it be more pain than its worth to get the heads off of the motor with it in the car. It just seems like it would be easier to do a spring swap with the heads off the motor.
Old Jun 12, 2007 | 07:36 PM
melchoir's Avatar
Leave the heads on.
Old Jun 12, 2007 | 07:53 PM
lastcall190's Avatar
Crane Tool and leave the heads on. I was rather aprehensive about doing the springs with the heads in the car too, but then I just finally borrowed the tool and did it. Not as bad as it seems, and you can have both of your hands free to mess with the locks and ****.
-J
Old Jun 12, 2007 | 07:57 PM
ChevyThunder17's Avatar
I would recommend using the pen magnets on the tips of the valve stem to hold the locks in place when you release the spring compressor.
And removing the heads is a lot more work than you want to have to do. You would need to clean the sealing surfaces, and every bolt hole needs to be dried out and the threads cleaned. It's really a pain to do. Plus you need a set of head gaskets.
Old Jun 13, 2007 | 08:00 AM
melchoir's Avatar
And new head bolts.
Old Jun 13, 2007 | 08:16 AM
Originally Posted by melchoir
And new head bolts.
I always forget about those. I picked up some ARP bolts. I like torqueing to a value, not an angle.
Old Jun 13, 2007 | 08:47 AM
GuitsBoy's Avatar
Not even close to being worth it. Heads are a HUGE pain in the ***. Use the TDC method, as I feel its much easier than the air method.
Old Jun 13, 2007 | 08:48 AM
TheLS1Kid's Avatar
Just take out your spark plugs and screw in an air fitting to hold your valves up.
Definitely get the Crane tool.
Old Jun 13, 2007 | 02:25 PM
radkon's Avatar
Use the crane tool
And plug the head bolt reliefs in the heads with some paper towels or rags. A buddy of mine had a lock drop down in there and we had to pull the head off to get it!
Old Jun 13, 2007 | 03:45 PM
tylerdj's Avatar
www.ls1howto.com They have a pretty good cam/valvetrain write up.
Old Jun 13, 2007 | 05:42 PM
john563's Avatar
Damn joel getting started already,huh.are you gonna add the Nx kit with the cam? what verter did you go with?let me know how it does when you get it installed and tuned.
