What causes a lifter to rotate in its bore?
Old Jun 15, 2007 | 07:15 AM
JimMueller's Avatar
Default What causes a lifter to rotate in its bore?
I'm trying to understand what may have caused this condition recently in my block and haven't had much success using search. Any ideas what I can do to reduce this in the future? Are the Morels with the bars combined with the Jesel retainers the only viable solution?
Old Jun 15, 2007 | 07:31 AM
WOTFMAN's Avatar
Take a stock lifter and compare it to a SBC one. Pay close attention to the bearing areas that ride in the lifter bore.
You will notice that the LS1 lifters have a bearing type ring on the top and bottom of the lifters. What generally happens is the aftermarket springs will cause a side loading effect on a somewhat aggressive cam lobe. You get the lifters to rock in the bore or a lifter bore that was slightly larger then the rest and eventually it will waller the hole out if you will and turn in the bore. When this happens the block usually can be repaired and fitted for a larger lifter like the better SBC ones. The SBC ones have a better bearing surface since most of the body takes the loads instead of just the two rings found on a stock LS1 lifter.
Old Jun 15, 2007 | 09:33 AM
p8ntmunky's Avatar
does this happen with the ls7 lifters also?
Old Jun 15, 2007 | 09:40 AM
JimMueller's Avatar
I have a set of Caddy race lifters which I hope won't have this issue.
Old Jun 15, 2007 | 09:44 AM
WOTFMAN's Avatar
I dont know what the LS7 or the Caddy lifters look like yet. If you have pics you could find out real quick in comparison to a stock LS1 lifter.
Old Jun 15, 2007 | 10:16 AM
p8ntmunky's Avatar
stocks on left
Old Jun 15, 2007 | 10:20 AM
WOTFMAN's Avatar
stocks on left
Id say yes it could still happen to the LS7's as well. Notice the bearing body is still in the same location as the stockers. Only thing they did was probably upgrade the internals for durability. The body of all LSX lifters id assume look like that and can be destined for disaster when used in extreme lobe profile cams. The lifter bores can be machined to accept the better SBC counterpart for minimal cost.
Google a SBC lifter and try to find a close up of it. I cant get on google for some reason right now.
Old Jun 15, 2007 | 10:32 AM
p8ntmunky's Avatar
Old Jun 15, 2007 | 10:37 AM
WOTFMAN's Avatar
Notice the thicker bearing rings on that lifter. Although better thats not the lifter I had in mind or have used in the past when combatting this type problem.
Old Jun 16, 2007 | 12:37 AM
eallanboggs's Avatar
The purpose of the lifter trays or link bars is to prevent this from happening. Unless they fail the lifter can NOT rotate. You didn't mention a lifter tray or link bar failure.
Old Jun 16, 2007 | 06:09 AM
JimMueller's Avatar
All we found was: Distorted lifter tray bore, flat-spotted lifter roller, roller stuck in lifter bore (tapped out with hammer on an old pushrod), and the damaged lifter bore. Oh, and the obvious metal bits in various places of the bottom end.
Now,this combination of heads, Comp cam, Comp OEM lifters, and lifter tray has been running fine in the same condtitions since spring 2004. So I don't understand what changed.
Old Jun 16, 2007 | 11:33 AM
JimMueller's Avatar
Here's something a friend came up with after talking to his machinist. What if I lofted that lifter at least once from holding it on my 7200 rev limiter for a few seconds? There were probably 15 laps, 40s each, where maybe I was on the rev limiter 3-5 seconds total during certain sections.
Also, upon disasembly of the heads, we found different size shims. This was apparently done the last time they were repaired after a blown head gasket, although I don't know if was the speed shop which handled the repair, or the shop they sent it to to fix the heads 'as best possible'. They are 918 springs, about 4 years old I believe.
If it lofted, will the new PRC Platinum springs and Cadillac lifters reduce that possibility? How else can I reduce lofting?
Old Jun 16, 2007 | 12:28 PM
hammertime's Avatar
I'd guess that in 4 years your 918 springs may have fatigued, especially if you are regularly pushing it to 7000+. If that's the case, more frequent maintenance might have helped, but thats just a guess. You should be able to pull them and check the free length, closed and open pressures against the new specs to verify.
Your other option is a rev kit, but I haven't seen very many for LS1's, so prepare to $$$ up if you choose that route.
Old Jun 17, 2007 | 12:17 AM
Is the Rev Kit currently available for the LS series? Last time I inquired they weren't making them for this engine.
Old Jun 17, 2007 | 12:28 AM
juiSSed1172's Avatar
Jim,
I just spun a lifter and chewed it up with my tr224. I was running 918s for a few years as well. My guess is that I had a spring fail, and the lifter 'hopped' on the lobe... My 918s saw about 40k+ miles.
My bore isn't damaged though, so I'm just installing a set of LS7 lifters, new cam, new springs/seats/seals and calling a day. (more like 4 months...)
Old Jun 17, 2007 | 02:39 AM
If you had a spring fail wouldn't you know it? You certainly would have discovered it during the tear down. Even if a spring failed the lifter tray would prevent the lifter from rotating. The lifter tray AND spring would have to fail simutaneously for this to happen. That's unlikely. The pin in the lifter roller could fail. The lifter roller and needle bearings would then come out in order for the lifter to leave its' bore. By that time the cam is shot. This is kind of unlikely as well.
Old Jun 17, 2007 | 06:28 AM
JimMueller's Avatar
ARE used to sell a LS1 Hyrda-Rev Kit back in 1998 or 1999, but I thought they stopped selling it because it 'wasn't needed'.
I found an old post which indicates 918's can't control the valvetrain above 6400:
https://ls1tech.com/forums/showpost....22&postcount=3
Can't find the link on Katech's site, but here is the text:
https://ls1tech.com/forums/showpost....59&postcount=5
The only thing I can find about a LS1 rev kit indicates to use lightweight components and the proper spring. My springs didn't break, but we didn't test the pressure. They may have been very weak.
Juissed: You were using a .650 lift cam on 918's? I thought Comp stated 918's were originally good to .625, then lowered it to .600 when their 921's came out? Or is that the new cam you're putting in? Which springs are you going with?
Old Jun 17, 2007 | 09:09 AM
LOL. No, the old cam was a 563/563 224/224 on the 918s. The new one is a MS4 with patriot dual gold's.
Old Jun 17, 2007 | 02:37 PM
WOTFMAN's Avatar
Yes it is available for these engines.
http://i30.photobucket.com/albums/c3...k/HPIM0624.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0622.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0621.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0625.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0626.jpg
http://i30.photobucket.com/albums/c3...k/HPIM0627.jpg
Old Jun 17, 2007 | 03:10 PM
vettenuts's Avatar
If you still have the lifter trays where the lifter turned, look and see if any of them were a #10. These were found to be an issue and were not correctly aligned. OK for stock, but once you push the motor and up the pressures there were issues.
