Replacing the TRex....Options?
Old Jun 16, 2007 | 11:38 PM
Ebbsnflows's Avatar
Default Replacing the TRex....Options?
I'd like to replace my Trex with something a bit smaller. Give me some alternatives that will improve driveability without sacrificing power.
My current setup is:
ARE Short block (Stock crank/Rods, ARP bolts, Forged Pistons)
PRC Stage 2.5 LS6 Heads with Double Springs
Cometic Head Gaskets .040
T-Rex cam
Hex Adjustable timming set
ASP Underdrive Pulley
Fast 78mm Ported intake
Ported Stock TB
QTP 1 3/4" Long Tub headers
Custom 3" H-Pipe into two Dynomax Ultra Flow mufflers Dumped
4.30 gears
6 speed
Old Jun 17, 2007 | 12:13 AM
juiSSed1172's Avatar
Ms4.
Old Jun 17, 2007 | 12:55 AM
SLP4CamaroSS's Avatar
g5x3 112lsa
Old Jun 17, 2007 | 01:56 AM
Xtnct00WS6's Avatar
I'd give the TRak cam a shot. It's not as big as the T-Rex, but you probably won't loose too much up top, but it'll idle better and be a bit more street friendly.
Old Jun 17, 2007 | 07:59 AM
Phil'sC5vette's Avatar
Im just curious, why do you want to change.
What about the Torquer 3
Old Jun 17, 2007 | 09:51 AM
Patrick G's Avatar
LS1 Tech Administrator
With the excellent exhaust flow, I'd recommend a single pattern cam and a little wider LSA. 236/236 .615/.607 112LSA +2. This will give you around the same DCR and power peak as the T-Rex, but with 12 degrees of overlap verses 25 degrees at .050".
__________________
2013 Corvette Grand Sport A6 LME forged 416, Greg Good ported TFS 255 LS3 heads, 222/242 .629"/.604" 121LSA Pat G blower cam, ARH 1 7/8" headers, ESC Novi 1500 Supercharger w/8 rib direct drive conversion, 747rwhp/709rwtq on 93 octane, 801rwhp/735rwtq on race fuel, 10.1 @ 147.25mph 1/4 mile, 174.7mph Half Mile.
2016 Corvette Z51 M7 Magnuson Heartbeat 2300 supercharger, TSP LT headers, Pat G tuned, 667rwhp, 662rwtq, 191mph TX Mile.
2009.5 Pontiac G8 GT 6.0L, A6, AFR 230v2 heads. 506rwhp/442rwtq. 11.413 @ 121.29mph 1/4 mile, 168.7mph TX Mile
2000 Pewter Ram Air Trans Am M6 heads/cam 508 rwhp/445 rwtq SAE, 183.092 TX Mile
2022 Cadillac Escalade 6.2L A10 S&B CAI, Corsa catback.
2023 Corvette 3LT Z51 soon to be modified.
Custom LSX tuning in person or via email press here.
Old Jun 17, 2007 | 03:59 PM
YOUNG's Avatar
What kind of power is your setup making right now?
Old Jun 17, 2007 | 09:15 PM
Ebbsnflows's Avatar
425 rwhp on a MUSTANG dyno (so roughly 440 or so on a standard dyno)
Old Jun 17, 2007 | 09:29 PM
Ebbsnflows's Avatar
I'm not particularly satisfied w/ the power it's making considering the poor driveability. If I made 460+ I'd suck it up....but for 425 rwhp (on a Mustang dyno), I want better street manners.
I'd almost beleive it was tuner related...if I hadn't seen the magic he's worked on countless other vehicles.
Old Jun 18, 2007 | 12:11 PM
Louie83's Avatar
When switching to a smaller cam, have you also considered milling your heads?
Old Jun 18, 2007 | 04:58 PM
Ebbsnflows's Avatar
Already milled...11.3/1 CR.
Old Jun 18, 2007 | 05:14 PM
Eurospec2's Avatar
Default trex
with those mods and that cam you should be making more power, and it shoudnt be a bear to drive, have you considered swapping tuners instead of swapping the cam
Old Jun 19, 2007 | 08:01 AM
LS1rulz's Avatar
Those look like good, REALISTIC numbers to me. Not the inflated internet numbers that a few shops put out, but realistic, accurate ones. Nothing wrong with that setup. Change cams like Patrick G said. Or get an adjustable timing chain and back off the cam's advance a little.
