MS3 question?
Old Jun 20, 2007 | 12:51 PM
allthrotle's Avatar
Default MS3 question?
Does anyone know if the MS3 cam is ground on a smaller base circle? Im trying to figure out what pushrod length I need to go with. Some people have told me longer and others have told me shorter.
Old Jun 20, 2007 | 12:59 PM
blk00ss's Avatar
If you are using stock heads, I think you can run stock length. 7.4 If you are that worried about it tho just get a pushrod checker.
Old Jun 20, 2007 | 01:07 PM
allthrotle's Avatar
Yep, I am running stock heads, but Ive heard you need a different pushrod length to keep the lifter pre-load correct.
Old Jun 20, 2007 | 01:28 PM
lowchevy2go's Avatar
No, stock size is fine. I have been running stock size since i did my ms3 swap a year ago. Some people go one size up but in alot of cases it has shown to be bleeding off compression.
Old Jun 20, 2007 | 02:36 PM
erikthegoalie's Avatar
7.400 here with prc heads and ms3....
i spin 7000, motor is quiet as a mouse, well, cept for the WOT part lol
E
Old Jun 20, 2007 | 02:39 PM
Jon@Texas-Speed's Avatar
7.400" pushrods will work fine. We use them in every install!
Old Jun 20, 2007 | 04:15 PM
allthrotle's Avatar
Thanks guys.
Old Jun 20, 2007 | 04:27 PM
Z28/2002's Avatar
From: Your girl's back door giving her the long stroke while you're at work
E
