Updating 98 Knock Sensors?
'98 models are prone to knock compared to the later years. To fix this problem I had Nick Williams Performance install new 2002 ZO6 knock sensors on my car prior to him tuning it with HP Tuners. With the tune with my QTP's I show absolutely no knock at all anymore. Just go to the Scoggin Dickey or GMPP website and look for the part number. Each sensor was around $50...$100 for both at the time.
I have not removed them yet, is the only difference going to be the plug connector? Are they physically the same as far as mounting?
2. Yes. The valley cover is the same from 98 thru 02.
During the 98 model year GM went from the 1st design to 2nd design knock sensor. Your car may have the newer knock sensors. Last September GM did change the part number on the 2nd design knock sensor.
Last week I did see a 98Vette with the 1st des sensors.
It would be interesting to see the stock tune files between identical year cars with same options with only difference being knock sensors, to see what was changed in knock tables. Can't jump up to 99 because the computer changed.
