Help with 6.0L budget build
Another thought would be to use the L92/L76 head/intake combo. Do know much about it. I have heard some debate about cam choice with this set up.
I seriously need some expert advise. I can only afford to do this once.
Opinions/ advice NEEDED!
thanks
https://ls1tech.com/forums/showthrea...9&page=1&pp=20
How much do I have to mill the 317 heads to get 10.5 to 1 compression with the stock pistons? Is there thinner gaskets to raise compression?
Simple Milling Math:
You have a stock 66cc chamber and you want to get down to 63cc
66-63 = 3. You have to remove 3cc's
.007 x 3 = .021. So to get your 66cc chambers down to 63cc you'd have to mill ~.021.
You can also do the reverse, say you want to mille a head .030 to figure out how many CC's that removes you take .030 / .007 = ~ 4.28. Milling a stock 5.7 head .030 puts your chamber at ~ 62.
Don't be afraid of compression, the more the merrier.
Granted you aren't shooting for 500rwhp, but read this it'll help you out on your build. The things in here are good ideas to think about whenever you are builiding an engine.
https://ls1tech.com/forums/generation-iii-internal-engine/732392-recipe-500-rwhp-heads-cam.html
http://www.carcraft.com/techarticles/ccrp_0705_chevrolet_ls2_l92_cylinder_heads/index.html
this is a great article
