piston and block ????
Old Jun 26, 2007 | 03:47 PM
stdjsw311's Avatar
Default piston and block ????
ok i have a 2000 z28 stock bottomend with a cam. i pulled the heads off yesterday and the piston is sticking out of the block about 1/16- 1/8th of and inch. should it be sticking out that far and is this normal???
Old Jun 26, 2007 | 04:47 PM
GuitsBoy's Avatar
No, they usually stick out .005 to .010. If youre serious about 1/16 - 1/8 then something is not right.... or at least not stock.
Old Jun 26, 2007 | 07:02 PM
ROCNDAV's Avatar
Yeah, my block was decked and my pistons only stuck out about .015".
Also is it only that one piston? check out the others.
Old Jun 26, 2007 | 08:12 PM
67Ranger's Avatar
That cant be right.... thats at least 0.0625 (1/16 inch). If that were so, your pistons would hit your heads every time the motor turned over, so that wouldnt be physically possible.You should go get a dial indicator and a deck bridge and check it out, and that will probably give you a little more accurate measurement.
Old Jun 28, 2007 | 09:18 AM
stdjsw311's Avatar
i will take a pic tonight and put it up to show everyone. i broke a valve spring and the valve hit the piston. well, i thought i could just replace the springs and the valves and get the head all worked over again then put it back together and it would work. well, it sounded like i spun a bearing when i put it all back together so i decided to pull it all back apart again and found the piston sticking up that far.
Old Jun 28, 2007 | 09:26 AM
GuitsBoy's Avatar
My guess is something broke internally. Not sure how it still held togather. Time to really pull **** apart.
Old Jun 28, 2007 | 03:38 PM
BIG BAD BLACKSS's Avatar
Do the other pistons come up just as far? Or is this one mysteriously trying to jump out and abandon ship?
Old Jun 28, 2007 | 08:44 PM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
Sounds like a wrist pin or rod bolt problem. I look forward to seeing the pictures.
