tech gurus i need some help
Old Jun 27, 2007 | 09:54 PM
khaos288's Avatar
Default tech gurus i need some help
i got my car all put back together and everything torqued down
but it cranks but won't start, we check fuel pressure and its got plenty
so we figure its a spark problem, theres one sensor that got broken when it was at the machine shop
its the little coolant switch on the drivers sideof the block, i got it on there bc it has the prongs and everything and still no start
i have the grounds all down but theres a couple on the same bolt, but that shouldn't be enough to stop the coilpacks from deciding to spark
so we're gonna change the plugs tonight and if it still doesn't start do you ls1 geniouses have any ideas?
Old Jun 27, 2007 | 09:57 PM
nofearracing28's Avatar
ground straps on the back of the head?
Old Jun 27, 2007 | 09:58 PM
khaos288's Avatar
i got the three on the back of the head
and the two ribbons up front
Old Jun 27, 2007 | 10:00 PM
Does it have any codes?
Old Jun 27, 2007 | 10:04 PM
khaos288's Avatar
i haven't been able to hook it up yet, bc i dont have a handheld, but are there any i should specifically look out for?
Old Jun 27, 2007 | 11:12 PM
waterbug1999's Avatar
That colant temp sensor will come into play, only after it gets warmed up as it will want to die on ya if its not workin.. so, keep an eye on that "when" you get her up and runnin...
Is it even trying to start? When I did all my stuff, I actually had the wire harness to the coil packs in "backwards"... I just had it flip floped in other words. So, 1 was plugged into 7 and 3 into 5. This was on one both sides so you can imagine what it sounded like.. Just a thought.
Old Jun 28, 2007 | 12:42 AM
khaos288's Avatar
mine only gets going with the starter motor, no spark at all
it has the fuel pressure but that one sensor is the only one not connectd
idkkkk ahh
Old Jun 28, 2007 | 12:48 AM
kistlerjm9's Avatar
i know it sound dumb but just make sure u have both connectors for the packs plug in and in the reluctor run out is more than .020 it wont start.
Old Jun 28, 2007 | 12:50 AM
khaos288's Avatar
reluctor?
i got the packs in idk what that is tho
Old Jun 28, 2007 | 01:15 AM
kistlerjm9's Avatar
what did u all do to the car first b4 we get into that and if u have aol instant messenger my screen name is kistlerjm9 im online.
Old Jun 28, 2007 | 01:33 AM
SSANIMAL's Avatar
Have You Checked Your Crank Sensor Or The Wire Connected To It
Old Jun 28, 2007 | 02:12 AM
khaos288's Avatar
i'm pretty sure i got all the sensors hooked up, which sensor is that?
Old Jun 28, 2007 | 05:40 AM
LS1MCSS's Avatar
It's the one behind the starter and it's a bitch to get to.
Old Jun 28, 2007 | 05:45 AM
edcmat-l1's Avatar
DING DING DING. Just hook up a scanner and see if you've got RPM.
Old Jun 29, 2007 | 12:09 AM
khaos288's Avatar
got it :-)
Old Jun 29, 2007 | 08:02 PM
Irocss85's Avatar
so that was it? crank sensor wasnt plugged in?
Old Jun 29, 2007 | 10:12 PM
khaos288's Avatar
yeh...
