Will a cam do anything for rasp?
Old Jun 28, 2007 | 04:16 AM
Silas2k's Avatar
Default Will a cam do anything for rasp?
i ran LTs and an ORY(dumped) for a little bit with no rasp, i put on the borla catback (not going thru the muffler, just out the back) and theres the normal mid-range rasp... my question is, would a cam (say 228/228 for ***** and giggles) "cure" the rasp? ive been getting so much conflicting info when i ask people this question...
Old Jun 28, 2007 | 07:47 AM
ramdaspadhye's Avatar
Nope. Prolly make it worse
Old Jun 28, 2007 | 08:52 AM
GuitsBoy's Avatar
yeah, it definately wont cure it. It will make the exaust louder as a whole. That includes the rasp rpm area.
Old Jun 28, 2007 | 10:14 AM
tylerdj's Avatar
I would suggest going to a catted y-pipe or possibly true duals if the rasp is really bothering you.
Old Jun 28, 2007 | 10:18 AM
LMz28's Avatar
"Will a cam do anything for rasp?"
yeah, itll make it worse.
is your borla adjustable? id screw around with that if it is. if that doesnt work, get yourself a borla XR-1 or something and slap it in the i pipe.
Old Jun 28, 2007 | 12:28 PM
Silas2k's Avatar
the borla is adjustable but unfortunately i only have the "fully open" plate... i think i may give in and do true duals... is there a company that makes under the axle and out the back duals? or am i going to have to make this custom and spend a lot of money?
Old Jun 28, 2007 | 01:20 PM
tylerdj's Avatar
No one makes a bolt-up true dual setup that goes all the way out the back as far as I know. I'm getting the TSP true duals and then having them ran under the axle and out the back by an exhaust shop. It's pretty cheap to have it ran under the axle though.
Old Jun 28, 2007 | 01:22 PM
landstuhltaylor's Avatar
bassini makes one in 2.5" diameter. it is designed for stock manifolds, but you could do some slight modifications to fit your setup.
Old Jun 28, 2007 | 02:12 PM
kistlerjm9's Avatar
a modified y pipe with a flowmaster merge collector will eliminate the rasp. instead of the exhaust smashing together hence creating the 2000-2500 rpm rasp.
Old Jun 28, 2007 | 02:16 PM
LMz28's Avatar
try the parts wanted section. itll definitely be the cheapest route. however, this does sound like a good excuse to go TD.
Old Jun 28, 2007 | 02:33 PM
tylerdj's Avatar
I stand corrected
What is the price for that setup?
