ls6 with a4 and stock stall?
How much is this remanufactured engine as I'm sure you can find something better for much less on here?
Stall wise you can throw what ever you want in there. Just remember you're going to have to drive it around and a 4400 stall isn't exactly the best thing for DDing.
Cam wise talk to PatrickG or PredatorZ. They are the cam gurus around here. If you're planning a budget build you might want to read this as it's based around budget setups:
https://ls1tech.com/forums/generation-iii-internal-engine/652563-reverse-torquer-cam-other-side-coin.html
