Solid roller question
Old Jun 29, 2007 | 09:28 AM
Gauge's Avatar
11Second Club
Default Solid roller question
Hey guys,
I've heard in the past that in order to switch to a solid roller setup the block had to be machined so that the lifter bores were bigger. Is this true? I can't imagine why the solid lifter couldn't have the exact same external dimensions as the hydraulics.
Gauge
Old Jun 29, 2007 | 10:56 AM
GuitsBoy's Avatar
You sure they wer'nt talking about machining out the spring seats so you could fit a much bigger / heavier spring in there to control the agressive cam profile? Perhaps it was an aged article and they were using BB solid lifters?
Old Jun 29, 2007 | 01:49 PM
erikthegoalie's Avatar
I would think that the solid lifters for LS motors would b the same size...wouldnt make sense to change unless strength was taken into consideration..
Old Jun 29, 2007 | 02:09 PM
Gauge's Avatar
11Second Club
GuitsBoy is right. This was my father talking about the 502 BBC in his Nova. I figured the LS1 and the BB would be the same in this situation... either both would require machining or neither of them. Why do the BBs need machining for solid lifters?
Old Jun 29, 2007 | 03:17 PM
GuitsBoy's Avatar
I believe the older BB chevys had larger bores than the standardized 1987+ lifter bore. I assume he was talking about using older BB lifters in an older SB application. Just a thought.
Old Jul 2, 2007 | 12:10 AM
Beaflag VonRathburg's Avatar
OWN3D BY MY PROF!
I'm pretty sure you have to machine the heads to accept larger 3/8 pushrods.
Old Jul 2, 2007 | 04:55 AM
LS1MCSS's Avatar
A lot of the lower horsepower big blocks used to come with 5/16 pushrods, for some reason, and you would have to open up the head a little to use 3/8 or 7/16. What you may have been thinking of, on the lifters, is boring out the lifter holes and pressing in a bronze liner. Older BBC's didn't have the lifter bores lined up true to the cam as good as they should have been. This used to be a common practice with the race engine builders, but it wasn't a very good idea for a street engine.
Old Jul 2, 2007 | 11:45 AM
DONAIMIAN's Avatar
Not really. It all depends on spring pressure. Theres a couple SR guys on here running your standard issue 5/16.
