quick question on cam install
Old Jun 30, 2007 | 07:32 PM
Daryn's Avatar
Formerly darynC-10/23/10
Default quick question on cam install
do you have to take the heads off?. if so , is it safe to use the stock head bolts? & what should they be tourqued to when puttin them back on
Old Jun 30, 2007 | 08:03 PM
sroach20's Avatar
not for just a cam install. you just pull the valve covers to pull the pushrods.
Old Jun 30, 2007 | 09:16 PM
onebadZ28's Avatar
You cannot reuse the stock head bolts. You will need to purchase a new set my suggestion woluld be to go with arp head bolts perferably studs.
Old Jul 2, 2007 | 07:17 AM
radkon's Avatar
No need to pull the heads.
If you do you need new head bolts, they are TTY one time use.
