LS6 Heads
Old May 10, 2003 | 12:48 PM
SlammedZ02's Avatar
Default LS6 Heads
Ok I'm about to order the LS6 Heads but I don't know how much to get them milled for a pretty big cam. Something like LG Motorsports cam the G5X2, MTI's X1 cam, or TR 230/224. Any kind of info can help. If you have any different opinions on a cam let me know and give me specs on the cam of your choice. I will be running the Stage II LS6 heads with 2.02int. 1.57exh.
Scott
Old May 10, 2003 | 02:12 PM
abnam68173's Avatar
Default Re: LS6 Heads
I would not get them milled at all if possible. With a .600 lift cam you will need to check piston to valve clearance.
