How high can i spin?
Old Jul 3, 2007 | 12:55 PM
3.4camaro's Avatar
Default How high can i spin?
Hey folks! Just got some TEA TFS heads and a cam setup, and I'm wondering how high i can spin without breaking anything. Car is a daily driver. The setup:
ARP rod bolts
ARP head studs
ARP crank bolt
TFS heads
TFS 228/230 .585/.585 112 cam
Caddy lifters
TEA supplied pushrods
Harland Sharp rockers
LS6 chain
LS6 oil pump
What do y'all think? What can I spin reliably?
Old Jul 3, 2007 | 01:12 PM
black01_WS6's Avatar
what springs did you go with?
Old Jul 3, 2007 | 02:40 PM
3.4camaro's Avatar
TEA supplied springs.
Old Jul 4, 2007 | 10:49 AM
3.4camaro's Avatar
anyone? to the top
Old Jul 4, 2007 | 11:22 AM
LS1rulz's Avatar
It depends what springs those are, of course.
Old Jul 4, 2007 | 12:11 PM
PREDATOR-Z's Avatar
With that cam anything past 6600 is futile.
Old Jul 4, 2007 | 12:25 PM
LS1rulz's Avatar
I think this one would've helped to spin further than 6600 on my 224/.581/112 even split:
Old Jul 4, 2007 | 07:29 PM
3.4camaro's Avatar
when all this stuff is in the car I'm going to the track to see what gets me a better ET. All futility aside, what can I spin to safely?
Old Jul 4, 2007 | 07:34 PM
LS1rulz's Avatar
Refer to post #5.
Old Jul 4, 2007 | 09:00 PM
BriancWS6's Avatar
You'll be able to safely spin it higher than needed. Our setups are very similar. The differences are my heads are AFRs and my cam is on a 114. My car peaks at 6400. Just set your limiter to 7k, and try different shift points at the track to see what it likes. FWIW, I have my shift-lite set to 6700, so the shifts probably occurring somewhere around 6800-6850ish.
Old Jul 4, 2007 | 10:02 PM
3.4camaro's Avatar
thats what i wanted to here. Thanks guy!
Old Jul 4, 2007 | 10:06 PM
BriancWS6's Avatar
No problem man, good luck, and post up some times
Old Jul 4, 2007 | 10:09 PM
3.4camaro's Avatar
1.300"dual extreme pressure (150# seat 450# open)
valve springs for lifts up to .650"
^^straight from TEA's website.
Old Jul 5, 2007 | 09:10 AM
GuitsBoy's Avatar
Id bet youll be fine spinning as high as you want (within reason) Set the rev limiter to 6800 - 7000 and hit the dyno. Find where you peak, set the limiter to peak+600 and shift at peak+400.
Old Jul 5, 2007 | 09:47 AM
slt200mph's Avatar
TEA uses a dual spring and are the Patriot Gold duals..they are good for more RPMs than you will need to turn..
Old Jul 5, 2007 | 03:10 PM
3.4camaro's Avatar
Well guys the headswap is going well. At the present, the heads and removed and I'm about to clean the deck and move my attention to the cam area. My former auto tech instructor(just graduated HS) was a mechanic and loaned me over $1000 in Snap-on air tools and torque wrenches....what a badass.
Unfortunately, I have to go to college orientation for 2 days so the job is on hault until I come back.
Thanks for everyone's help and support.
