98 z cracked block replace with LS2?
Old Jul 7, 2007 | 10:47 AM
jethro81z28's Avatar
Lightbulb 98 z cracked block replace with 6.0?
I have a stock 98 LS1 6 speed that has a cracked block, I could not find a short block so a friend of mine found a cast iron short block6.0 based on the ls2 I think came out of a cad. escalade block has less thin 48000 miles I would like to put that in my car. My mechanic said that it would work with a little mods. The original owner gave me a hot cam when I bought the car, it’s a lunati cam with a 565 lilt. My mechanic has a machine shop and would do all the work,stud the mains and put new springs and a good head job on my stock heads and put it in my car for 1000.00 would this be a good combo and would it give me additional horse power ?. The second choice is the same as above but with L92 heads and a L76 intake for a additional 1500 ? But I would like more feed back on the first choice. Thanks Mike
Old Jul 7, 2007 | 11:30 AM
PREDATOR-Z's Avatar
LS2 is Aluminum not iron. Also no need to touch the mains.
Buy a 347 shortblock forged for now and add mods as money becomes available.
You can find a forged block for $2800 or less. Shop around.
Old Jul 7, 2007 | 02:12 PM
Motor is a 6.0 and is free , and all my components will fit (on a budget) thanks
Old Jul 7, 2007 | 03:23 PM
1999ssls1's Avatar
Go with the 6.0 and l92 setup. That is for sure a good power route.
Old Jul 7, 2007 | 03:30 PM
The cam I have in the box is a Luntia 221 221 @ 50 and 558 558 lift on 112 does that sound like a good cam for my combo?
Old Jul 7, 2007 | 03:33 PM
1999ssls1 how fast is your car, sounds sweet to me. Did all the comp.and sencors and connetions hook up allright did you have to use a program ?
Old Jul 7, 2007 | 08:54 PM
Could anyone give a hp guess on stock 6.0 with my cam and L92 heads?
Old Jul 7, 2007 | 08:56 PM
98SS1LWEE's Avatar
IF YOU'RE GOING L92/L76, THEN I SAY LITTLE BIGGER CAM, ATLEAST. i KNOW YOURS WILL make good power, but you could benefit with those heads and a few more cubes than the 346 by using a bigger cam.
Old Jul 7, 2007 | 09:20 PM
01FormulaTA's Avatar
with full bolt-ons and a good tune I would say 430+ rwhp......the new LS3 vettes with just an air filter and longtubes on the stock tune made 423 rwhp....they all use the L92 heads and L76 intake but have a little bit of extra displacement at 6.2L's.....make sure you at least upgrade the clutch and prob have the tranny rebuilt also.....and hard launches will be out of the question if you still have the stock 10-bolt junk
Old Jul 7, 2007 | 09:29 PM
the_merv's Avatar
Veteran: Air Force
Good choice with the Iron 6.0, and the L76/L92 setup, I would definately go with a bigger Cam though. Look at the flow numbers on those Heads, you will see why.
I am doin the same setup, except with a 6.6l 402ci bottom end, and this is the Cam I am putting in: 243/247, .621 XFI/.612 X-ER, 114+3LSA
That was recommended to me with my setup, I am going to be around 10.8:1 Comp. With all the supporting mods(Intake/Exhaust..etc), I am hoping for around 480rwhp numbers..
Old Jul 7, 2007 | 11:03 PM
What would be a good cam? 6 speed Stock6.0 Iron block L92 heads and L76 intake with a good set of headers and exhaust.
Old Jul 8, 2007 | 12:17 AM
1999ssls1's Avatar
I havent had it at the track with the 6.0 yet, nor had it dyno tuned yet. The sensors are all in the same place as the ls1. It seems to pull alot harder than the ls1in my opinion.
Old Jul 8, 2007 | 12:41 AM
Tainted's Avatar
go way bigger on your cam
Old Jul 8, 2007 | 01:00 AM
PREDATOR-Z's Avatar
It has nothing to do with bigger. It has to be a cam designed with the proper valve events and duration splits for the L92 heads.
Too many poeple here shooting advice without knowing the parameters of the combo.
The 221/221 will work poorly with L92 heads.
You said 6.0 iron block, is it LQ9 or LQ4? one has flat top pistons and the other dished.
In a nutshell, you can use that cam 221/221 in the 6.0 with freshened stock heads, not optimum but you said "budget".
Any other than your perimeter bolt heads and you have to consider coil bracket and other valve covers.
Patriot offers ported perimeter heads for less than $1000 with gaskets I believe, this might be the right choice $$ wise for you.
To recap;
6.0 shortblock (LQ9 or LQ4?)> Free
PP heads > $1000
Cam> 221/221 lunati> Free
Now all you need is the gaskets, fluids, new replacement oil pump and LS2 chain/sprocket kit.
Put it all together for a decent torq/Hp output.
The biggest issue is the intake, you should try to find either used LS6 or LS2 intake and TB.
Old Jul 8, 2007 | 10:18 AM
Good advice from all, now I need to decide what I want to do with the car .money or keep it simple these cars or so easy to make power its hard to believe on my 81z I had to take out a loan just to do the upgrades to get 450 to 475 horse (dyno @ the wheel 355) here’s some pics and what I had to do to get that horse power. http://www.cardomain.com/ride/774485
Old Jul 8, 2007 | 11:53 AM
gielr's Avatar
have the same problem, 98z with cracked block i bought it like that.i got a 6.0 from a 03 hummer
my question can i transfer all my accessories and intake from my motor to the 6.0?
do i need to change the cam from my z to the 6.0 for more power and torque
also the 6.0 has 2 plugs on top mine has only one why?what are they ?will it work?
thanks gielr owner 1987 iroc-z and soon to be 98z-28
Old Jul 8, 2007 | 05:31 PM
the_merv's Avatar
Veteran: Air Force
You have to Drill and Tap the upper Ear on the Drivers Side for one of the Alternator Bolts.
Old Jul 8, 2007 | 11:52 PM
PREDATOR-Z's Avatar
Not necessary unless you run FI and even then.... I run mine with only 2 bolts, no issues.
Old Jul 9, 2007 | 02:23 AM
the_merv's Avatar
Veteran: Air Force
I still did it for the extra security..
Old Jul 9, 2007 | 05:39 PM
block has flat top pistons.
