Torque Specs
What is up with this degree **** after the first Torque Stage..
I know that you are goin to have Bolt stretch when you Torque them in, that is why you check them after a while, expecially some of the Head bolts, but what happened to the old way..first stage this, second stage this, and you were done..
Is there a way to take this degree **** and figure out what Torque it would be..
Example: Main Caps. calls for 15 ft/lbs, then 80* for the inners, 53* for the outers..
How about 15ft/lbs, then 70ft/lbs for the inners, 60ft/lbs for the outers.
The Heads I was going to go to 10ft/lbs, second stage 35ft/lbs, 65ft/lbs final then check them.
I am an Iron Block Engine..so I figure I would be able to get away with that cause there is alot less flex.
I did my LT1 the same way and didn't have any problems..good ole Iron Engines..alot easier to work with.
The Head Bolts are GMPP Bolts, these are it here:
http://store.summitracing.com/partde...5&autoview=sku
If I had to, I could go to these..
http://store.summitracing.com/partde...1&autoview=sku
