ls1 valve in ls6 head?
Old Jul 8, 2007 | 08:38 PM
xBROKEx's Avatar
Default ls1 valve in ls6 head?
is that doable?
I have an aftermarket cam and am wanting to put my ls6 heads on but I was wondering if I could re-use my stock ls1 valves and 7.4 TR pushrods on the LS6 head.
thanks for all the help
Old Jul 9, 2007 | 05:38 AM
xBROKEx's Avatar
bump.
Old Jul 9, 2007 | 05:55 AM
RZRSEDGE's Avatar
Pretty sure that they will work. The only difference, if I'm not mistaken, is that the '02 - '04 ZO6 LS6 head had the sodium filled exhaust valve while the '01 ZO6 head and the LS2 heads, all 243 castings did not. Hope this helps!
Old Jul 9, 2007 | 06:09 AM
xBROKEx's Avatar
that is what I was thinking...I'll double check w/a vendor...thanks for the input
Old Jul 9, 2007 | 06:26 AM
RZRSEDGE's Avatar
No problem!
Old Jul 9, 2007 | 12:08 PM
PREDATOR-Z's Avatar
Yes same stem size but length may vary (aftermarket)
Also you need a valvejob on any new valve you put in, even used.
And with stock seats no bigger than 2.02 intake and 1.57 exhaust
Old Jul 9, 2007 | 04:43 PM
xBROKEx's Avatar
I was planning on moving my current ls1 valves into the ls6 head....is the valve job really necessary?
how much is a valvejob?
Old Jul 9, 2007 | 09:37 PM
xBROKEx's Avatar
tr says they're not 100% sure , anyone else confirm or know of anyhone who has done the same?
Old Jul 9, 2007 | 11:29 PM
KCS's Avatar
KCS
Moderator
It's may not be necessary, but definetly worth it. You could lose alot of power if the valves don't seal very well.
FYI, I just got a set of stock 853 heads from a guy and all but a few valves were bent. This was with a stock cam, valvetrain, and stock rev limiter. The stems were OK, but the valves' heads were tuliped. It wasn't bad enough to keep from getting a concentric seat cut into them, but a clean backcut was out of the question. At the very least, get a valvejob and have the valves lapped.
Old Jul 10, 2007 | 12:34 AM
PREDATOR-Z's Avatar
YES it is necessary, why take a shortcut on something like this. That would be stupid IMO.
