03 Z06 AFR heads?
Old Jul 9, 2007 | 09:32 AM
44mag's Avatar
Default 03 Z06 AFR heads?
I just bought an 03 Z06 and was thinking about putting the Afr 205s on along with supporting mods like LG headers, Cold air, etc. Would the Afrs really help with the stock cam? I Know there are alot of good aftermarket cams out there but I would like to keep the stock one for know. I guess my question is would the Afr heads make a big difference? I would like to know how much power i can get with the Ls6 cam.
Old Jul 9, 2007 | 10:02 AM
1997bird's Avatar
They would help make more HP, but I would wait until your ready for a cam and buy both together.
Old Jul 9, 2007 | 12:18 PM
PREDATOR-Z's Avatar
You would have to mill them a bit for LS6 stock compression or even better for 11:1 compression. You will see at least 40+rwhp properly tuned. I would mill them to 62cc and run .040 gaskets.
Old Jul 9, 2007 | 01:47 PM
wildta's Avatar
You can buy some ported LS6 heads from Texas speed and Performance and some 1.85 rockers (used) I think that will put you at 400+ hp at the wheels!
Ported LS6 are half the price of AFR
Old Jul 9, 2007 | 04:51 PM
44mag's Avatar
Thanks guys!
Old Jul 10, 2007 | 12:39 AM
PREDATOR-Z's Avatar
No comparison
Old Jul 12, 2007 | 02:12 PM
Phil'sC5vette's Avatar
AFRs will always put up better numbers
Old Jul 13, 2007 | 04:50 AM
vettenuts's Avatar
Vinci did a "head's only" swap to an LS1 using AFR heads. The results are on their web site >>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>>
Old Jul 21, 2007 | 03:07 PM
mrr23's Avatar
http://vincihighperformance.com/BECK...CT%20PAGE.HTML
took a completely stock C5 and put the AFR heads on it. gained 39.5 rwhp untuned.
Old Jul 21, 2007 | 04:13 PM
orangeapeel's Avatar
ЯєŧąяĐ Єl¡m¡иąŧøя ™
Make sure you don't run outrageous rockers either. I would stick with the stock ratio.
