stupid lifter question
Old Jul 9, 2007 | 08:20 PM
92ZZ3RS's Avatar
Default stupid lifter question
there is a hole close to the top on one side of the lifter. does it face up or down when putting the lifters in. i think it faces down but unsure. thanks.
Old Jul 9, 2007 | 09:53 PM
ERIK@MASPORT's Avatar
Closed Sponsor Account
The lifters only go in one way...not sure about the hole...probably an oiling hole you are talking about...
I would not worry about it---->oil lifters, insert into trays (only slide in one way, roller down) and slide into lifter bores, push down onto lobes of cam with pushrods, done
You're good to go..
Erik
Old Jul 9, 2007 | 10:07 PM
92ZZ3RS's Avatar
there is 2 ways the lifters will go in. either with the little hole facing up (towards intake) or down (towards pistons).
Old Jul 9, 2007 | 11:33 PM
cals400ex's Avatar
the little holes on the sides of the lifters all faced the front of the car when i removed mine.
Old Jul 10, 2007 | 03:25 AM
92ZZ3RS's Avatar
there is only one hole per lifter and it can not face the front. it can only be top or bottom
Old Jul 10, 2007 | 04:42 AM
maybe a pic will help...there is only one "up" and one "down" with a lifter
E
Old Jul 10, 2007 | 06:19 AM
striker754's Avatar
hes talking about the sides of the roller, being able to rotate it on its axis and insert it in different directions.
I think he knows that the roller goes down....
Old Jul 10, 2007 | 07:49 AM
92ZZ3RS's Avatar
yes i know the roller goes down.
Old Jul 10, 2007 | 08:55 AM
You must be referring to the OILING hole, which I mentioned previously. That would be left and right orientation, not up and down...
That is why I was confused lol...
Orientation does not matter.
Oil will get there either way.
If you are concerned, you could always drill the lifter trays a bit to allow for more oil to come in...I never have, but you can.
this wasn't clear, sorry...
Old Jul 10, 2007 | 09:43 AM
92ZZ3RS's Avatar
thanks for the help. i checked online at alldata and it does not say either. i also looked today on the gm website here at work and it does not say either. i was told by the tech that it does not matter either. i work at a chevy dealer and i knew it was a stupid question but i would rather be sure when it comes to stuff like that.
Old Jul 10, 2007 | 11:41 AM
Hey. no such thing as a "stupid question"....better to ask than to screw something up!!
It is for this reason that the best athletes still have coaches helping them along the way!
Good luck
Erik
Old Jul 10, 2007 | 06:27 PM
DaddySS's Avatar
it doesn't really matter but I looked at the oil flow diagram and faced the oil hole toward the source of the flow.
Old Oct 20, 2023 | 08:02 PM
WebKruzer's Avatar
Thank you "ERIK@MASPORT
Old Oct 20, 2023 | 08:03 PM
WebKruzer's Avatar
Thank you DaddySS for your help.
Old Oct 21, 2023 | 04:07 PM
grinder11's Avatar
"Erik" last posted in 2010, so he'll probably not respond...
Old Oct 27, 2023 | 03:48 AM
gagliano7's Avatar
It doesn't matter which way the go but i always face them up since gravity will bring the oil down.
