Tune or break in rebuilt lq9
also have a 210/218 drop in truck cam and 243 heads on it and Long tube headers
also what’s a good break in procedure?
Bad tune could cause several issues.
Besides tuning the engine on the chassis dyno the tuner can also fine tune the shift points on the trans.
You really need to get it to a tuner as soon as possible. They can probably send you a base tune that might get you there. Your next best option would be towing it to the tuner.
I could be wrong but I thought all the truck intakes and injectors were the same regardless of the displacement?
Either way I think it's okay If OP kicks it over You can button it all up. Take care of leaks etc. It's fine, Just don't race it until you have it tuned
I don’t seem to understand the issue because he said it hasn’t thrown any codes and also almost everything in the motor is new excepts from spark plug and wires and also the injectors those reused from the 4.8?
what could be the issue?
After years of believing others were smarter than me and my car I finally wizened up and bought the software for myself. Best purchase I've ever made in this hobby hands down
I really don’t have a clue by that because he said the transmission oil not being topped off but i was sure of it and the transmission was a rebuilt one from a trusty builder that i had already tried on before swapping my motor so that can’t be it
That’s what I’m starting to think Also starting to believe is just a case of wanting more money because he said he’ll give me a diagnosis for 110 an hour just to see what it is not even fix it
