Pulling motor out the top question
Old Jul 10, 2007 | 07:20 AM
theblur98ss's Avatar
Default Pulling motor out the top question
I know this gets asked alot but search isn't working. I've always taken my motor out the bottom but would like to pull this one out the top. I have the heads and intake off. Where does everyone hook the cherry picker up to? I put two bolts in the top where the knock sensors go but the arm isn't long enough on the hoist. Also can I pull the tranny at the same time or should I drop it first.
Old Jul 10, 2007 | 07:24 AM
1999ssls1's Avatar
Leave the tranny on and put the chain through some head bolts and bolt it to the block.
Old Jul 10, 2007 | 07:30 AM
brad8266's Avatar
Try this high speed lifting plate from QTP. http://shop.quicktimeperformance.com...ct_detail&p=61
Old Jul 10, 2007 | 08:18 AM
Should I hook the hoist on towards the front of the motor or over the center?
Old Jul 10, 2007 | 09:48 AM
rpmauto's Avatar
do you have to have the heads off to remove the engine with the qtp plate???
Old Jul 10, 2007 | 10:22 AM
DONAIMIAN's Avatar
I bought a QTP lift plate, although the hoist I used was too short...so I learned how to take the front bumper off. No big deal because ive been meaning to do some stuff behind there anyway.
Old Jul 10, 2007 | 11:22 AM
warp_6's Avatar
No you can use it with the heads on
Old Jul 10, 2007 | 11:51 AM
N4cer's Avatar
I've always just put a bolt in the rear passenger head, and front driver head, and hooked the chains up there. Tranny unbolted though.
Old Jul 10, 2007 | 01:05 PM
NemeSS's Avatar
bolt from pass. head cross to rear driver head bolt where ground is
i have an x chain i made and bolt to both heads, like x pattern
with any trans and acc., minus ac comp. aslo helps to remove alt.
but not necessary, i prefer to remove engine from top, takes me longer to
disconnect water lines and wiring, and to unbolt trans, tq arm, etc.
Old Jul 10, 2007 | 04:07 PM
Captain InsaneO's Avatar
I have helped install and remove 4 engines from the top. I used what's called a "Happy Hooker" I found off ebay. I keep everything on the block except the A/C, Alt. and PS pump. We have even removed the engine with the tranny still attatched.
On average it takes about 15-20 minutes to remove it from the top once everything is disconnected.
Old Jul 10, 2007 | 04:32 PM
Evans752's Avatar
If you have a lift you can drop it out the bottom but me I usually pull the tranny and take a big nylon rachet strap and put ot around the crank pulley and 1 pont dead center of the block(top bell housing bolt and pull it out the top. If you have a lift then the bottom is the best way. Good Luck
Old Jul 19, 2007 | 11:45 AM
I got one of the qtp lift plates and it worked out very nice. It's almost too pretty for what it's used for though. I wish my valley cover was that shiney.
