What Heads W/ Tr224 Cam
p.s. i'm not claming to be an expert ,but having a little insurance on the springs lift is a good thing is what i've been told.
. unless you consider $995.00 a deal for you from livernios
I know PP mills at no charge and throws in gaskets I believe.
Now if you want to change cam, that is a different story.
Then buy the heads you can afford and then choose a cam that works with your head motor combo.
The cam is the last thing you choose because they can be custom tailored for the overall combo.
Checkout GM High Tech performance if your set on running LS6 heads. We had a recent article in there that shows detailed gains from just the installation of our PRC LS6 cylinder heads.
It would also be very benificial if you'd spend some extra time searching the dyno results section of ls1tech. I think when you research dyno results you'll find the PRC heads will get you the power you expect.
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
With a smaller cam like that, you may also want to consider milling and running a thinner gasket for more power out of a budget combo!
Erik
If you want budget and the best service you go Patriot and Gunnar.
Next in line for budget reasons is Texas Speed.
Then the rest of them line up unless you want the best then its AFR. I know someone with MTI stage 3 heads and he is very happy with them.
The best are still AFR's. I've spoken with a few vendors on here about heads and one thing is for sure. Tony Mamo at AFR knows his ****. Others might know what they are doing but they were so concerned about disiing TSP and the rest of their competition that I wont buy from them ever... like TEA.
One thing you will find on here is brand loyalty. The hardest thing to discern on here are facts from opinions. Dedicated head vendors are ahead in the game. Thats all they do and all they do to make a living is sell heads. It makes a difference in the end product from what I can see and I've got my 3rd set of heads coming.
Milled to 59 cc would equate to too much DCR, wouldn't it? What would be the safest mill for this combo, 61 - 62 CC?
