my cam only gave me 4 tenths of a second..
so the rear lower control arms should help the wheelhop right? should i get the tq. arm deal at the same time or it this not as important? and my car doesnt wheel hopp on the street only at the track..
LCAs will help address the wheel hop.
Wheel hop eats driveshafts..SO if it hops,lift!
Location: Your girl's back door giving her the long stroke while you're at work
#35
Add me to the list that can't understand why you are disappointed. Actually, you might want to start a new list of folks who are surprised that a cam with those specs gave you that much.
#36
you have a 98 a4 only mods are a lid, cat back and small cam..get the rest of the bolt ons, and im guessing you have 3.23 rear? get some 3.73 and a good size stall and you may be able to hit 11s
#40
my car will be done this friday with almost the same cam except my lift is like 555 558 i dont know how much difrence that will make though my duration is stil 212/218 so will the lift change much from his cam or what just curious
