6.0 block sonic test results
You can see why some have problems going .060 over
If I was to bore that cylinder .060 over, that only gives me .070 of cylinder wall left(half of .060 is .030). Not a good thing if you run high CR, nitrous or boost. I'll post my similar results of my brand new 6.0 GM block soon (2nd block I had tested). I had these blocks tested since I already purchased .060 pistons.
Looks like I will have to sell the pistons (if I can), Edit: Trying to do the math on the cylinder 2nd row on the right where it's 100. How would you still retain .090-100 on that one? Even if you bore it off center, it still would be too thin.
You can email your sonic test to this address and I will post it:
ratacal@yahoo.com
I would rather have the comfort of knowing I can spray the **** out of it if I wanted to
Here's my sonic test on my new 6.0 block I got from GM:
