5.3 Head Gasket
For 97-01' style heads GMPN 12498543
For 02-03' style heads GMPN 12498544
I know that the heads are brand new but I do not know if they are considered the newer style or the older style? I would just call TEA but it is hard for me to get home from work before they close. Does anyone else with these heads remember which head gaskets they used?
So, you can use either the GM graphite style or the 2002 multi-layer shim style.
If it were me, I would use the graphite style. They seal better.
Scoggin Dickey Parts Center sells this as > Head gasket set (graphite style), P/N 12498543, $34.95 for the set of two.
The head Gasket Set above includes: Gasket P/N 12558809 (Lft side) & Gasket P/N 12558810 (Rt side)
These graphite style head gaskets can be used on all year models.
__________________________________________________ ______________
They also sell the GM multi-layer style head gaskets as a set. These cannot be used on early style LS1 heads with witness notches.
Good choice on the TEA 5.3L / Stage 1.5 heads.....
Ron,
ive got all the parts, just needs the heads now..
hello 11.0-1's hopefully
