Valve spring swap help
Old Jul 14, 2007 | 08:18 PM
delsold's Avatar
Default Valve spring swap help
I just installed my cam today, and i just started doing the valve spring swap tonight. I'm using a leakdown tester to hold the valves up. My air compressor doesnt have that great of a regulator on it, and i think that might be part of my problem...but lets hear your opinions
when i apply air into the cylinder, i hear hair in the crankcase. The car has near perfect compression, and never had a cylinder leak issue. once i start using the crane tool to push the spring down, i can hear a big rush of air, so i know im just opening a valve and the air isnt holding them up
what do you guys think?
Old Jul 14, 2007 | 08:24 PM
gillbot's Avatar
I use the TDC method myself.
http://dayton-fbody.com/DFBAbb/viewt...?p=10858#10858
Old Jul 14, 2007 | 08:40 PM
098z28's Avatar
i put 120psi to my cylinders, no problems also is it possible that u might be pushing the vale open when you are trying to coompress the spring? i had to 'tap' my retainers with a small socket slightly bigger than the valve stem and locks to free it up
Old Jul 14, 2007 | 08:43 PM
delsold's Avatar
that is what i was thinking...that the locks might be stuck and just pushing the valve open...but htat still doesnt explain my air noise i hear? Its not coming out of my exhaust or intake, and i dont feel any coming out of the front of the block.
Old Jul 14, 2007 | 09:05 PM
098z28's Avatar
well i had air leaking all over the place lol since i made my own little conncetion, dont be afraid of some leakage i dont imagin it takes much to hold the valves up, or just use the tdc method i used air on the drivers side but tdc on the passenger side b/c i couldnt fit my connection
Old Jul 14, 2007 | 09:15 PM
delsold's Avatar
ok ill try that! thanks for the advice....if i have any more issues ill be back on the number one resource for advice on **** you cant figure out yourself...ls1tech!
Old Jul 14, 2007 | 10:50 PM
STALL UP's Avatar
I would use the top dead center method I sliped and dropped a valve on the last valve on the driver side using 120psi and had to pull the heads. So just be careful using air
Old Jul 14, 2007 | 10:53 PM
sroach20's Avatar
i used 70 psi like the tool i bought on here said. it held the valves up and it still hissed. havent had any problems with the heads either.
Old Jul 14, 2007 | 11:05 PM
SSsuperdave's Avatar
I had good luck w air. I used like 100 psi I think and also had to tap the retainer to break 'em loose. I had air leaking by the rings too, and I got over 200 psi compression but it's not a problem, Just leaking down.
Old Jul 15, 2007 | 08:24 AM
delsold's Avatar
ok thanks guys!...im gonna try a few with air, but ill make sure they cylinder is close to tdc just incase it feels like being a bastard and dropping....because my wallet would kick my *** if i had to pull the heads
Old Jul 15, 2007 | 12:23 PM
098z28's Avatar
update?
Old Jul 15, 2007 | 02:03 PM
ls1pwrdss's Avatar
just tap the retainer with a hammer and the use the tool and should work fine for you
Old Jul 15, 2007 | 07:47 PM
eallanboggs's Avatar
You can use the TDC method with the compressed air. Once #1 is at TDC you can do 2 cylinder then rotate the crank 90 degrees and do 2 more then repeat. Don't use anything near 120 psi. That's enough to spin the crank if the piston is exactly at TDC especially if the spark plugs are removed. The crane tool is the best. It removes/installs 2 springs at a time. It's a time saver.
Old Jul 15, 2007 | 08:05 PM
White_Ls1's Avatar
I used 80-90 Psi and it held fine, make sure you have a good o-ring on your leak down tool(hearing air is normal) I also use the TDC method 1 & 6, 8 & 5, 7 & 4 and 3 & 2 using a straw as a feeler. I tied a strap to a breaker bar and had it attached to the crank bolt to keep the piston from pushing down. Good Luck -Dave
