Blown motor?
Old Jul 15, 2007 | 10:08 AM
Sxyman815's Avatar
Default Blown motor?
So I'm going down the strip and hit second and climbing fast and 6000 rpm comes and I go to shift and it doesn't come out hits 6700 rpm and shuts off now when I crank it, it doesn't sound like there is any compression high pitch cranking anyone have any ideas before I pull it for a rebuild?
PLEASE HELP!
Old Jul 15, 2007 | 10:15 AM
RE AND CHERYL's Avatar
Do a compression check. You might have bent pushrods when you over reved it. I assume you have stock valve springs.
Re'
Old Jul 15, 2007 | 10:17 AM
Sxyman815's Avatar
Default All Stock
Yes the motor is all stock bent push rod would lead to the same sounds and probs I'm having?
Old Jul 15, 2007 | 01:34 PM
Sxyman815's Avatar
Default Help
Bump Bump...
