Heads/cam vs. cam only
Old Jul 19, 2007 | 09:41 AM
Websy21's Avatar
Thats sounds great to hear because last week I just ordered a 224/228 .581/.588 114LSA comp, I knew that this cam wasn't going to be too agressive but still I was curious. The reason I chose this was becasue I had plans of going forced induction but I may swing to a nice set of heads now and was worried I never had a more aggresive cam. The lift and duration isn't too bad but If I knew I was going H/C I would have atleast taken this cam on a 112LSA.
Old Jul 19, 2007 | 10:03 AM
cals400ex's Avatar
what does +4 mean? 4 degrees advanced? is a degree wheel a must for that?
Old Jul 19, 2007 | 12:04 PM
Raise's Avatar
yeah +4 is 4 degrees of advance. its actually ground into the cam in production.
Old Jul 19, 2007 | 12:06 PM
brad8266's Avatar
If the advance is not ground into the cam then you need a degree wheel to dial it in.
Old Jul 19, 2007 | 05:45 PM
silverlt1ss's Avatar
Originally Posted by BIG_MIKE2005
This is interesting since I just completed my H/C swap. After talkin with Bo White & PREDATORZ, I ended up goin with a set of port/polished & milled .018" 5.3L heads, Thunder 7.4 pushrods, stock rockers & 224/.581 114 cam.
It idle perfect @ 900 RPM like stock & has zero surge under 1000 RPM in 1st gear pullin out of my driveway. I never expected it to be this smooth of a combo. There is no valvetrain noise so far & my gas milage is exactly the same from what I can tell. And I don't even have a tune on it yet. I can't wait to hit the dyno after I get this LS1 intake swapped out. I got a port/polished Lingenfelter, but the fittings were wrong so it had to come back off for now.
my car is the same way, it starts to surge at 1800,
Old Jul 19, 2007 | 05:48 PM
i got this cam for my girlfriends ws6, i also picked up a new set of ls6 heads. this cam is actually the one out of the pinks 240 car. ls7 lifters with stock length rods and a melling oil pump is gonna be her combo. o yea an ls6 intake with a ported TB.
By Brett Foote | 2026-06-04 05:00:17
