everything needed for cam swap?
<small>[ January 30, 2003, 07:38 PM: Message edited by: hugcam ]</small>
To answer, you need 2 waterpump bolts, 2 AIR tube gaskets, a crank pulley bolt, and a front seal. The part #'s are all on my website.
Crank bolt: 12557840
Front seal: 12561244
Timing cover gasket (if you want to replace it): 12558013
Valve cover gaskets X2 (again, if you want): 12560696
