Will I have enough piston to valve clearence?
Old Jul 19, 2007 | 12:28 AM
allthrotle's Avatar
Default Will I have enough piston to valve clearence?
I have an ms3 cam, and I just bought some patriot heads part #2029. I forgot to check and see but, the combustion chambers are 59 cc's I am not sure if they have been decked or not and I was wondering if I was going to have piston to valve clearence problems?
Old Jul 19, 2007 | 02:40 AM
PREDATOR-Z's Avatar
It depends if:
heads were milled
Size of valves used
Gasket used
and partialy what LSA/ICL of the MS3
Old Jul 19, 2007 | 07:17 AM
brad8266's Avatar
^^:what he said.
BTW, those heads probably have not been milled, they have welded chambers in order to acheive the chamber size.
Old Jul 19, 2007 | 10:01 AM
allthrotle's Avatar
Im using stock gm gaskets, compressed thickness is .052 I think, my ms3 is on a 112 lsa. I think Ill be fine I was just double checking, I dont want to have to spend more money than I have to.
Old Jul 19, 2007 | 10:26 AM
Jason 98 TA's Avatar
LS1Tech Premium Sponsor
The MS3 camshaft will not clear with a larger valve than the stock 2" valve. As long as you get a 2" valve & a 1.55 exhaust valve you should be fine.
__________________
Jason
Co-Owner, Texas Speed & Performance, Ltd.
2005 Twin Turbo C6
404cid Stroker, 67mm Twins
994rwhp/902lb ft @ 22 psi (mustang dyno) www.Texas-Speed.com
Old Jul 19, 2007 | 12:45 PM
allthrotle's Avatar
The valve sizes on the heads are 2.02 and 1.57 are these not going to fit with my ms3?
Old Jul 19, 2007 | 12:57 PM
PREDATOR-Z's Avatar
Did Jason studder or are you shocked??
NO, you'll need to flycut a little.
Old Jul 19, 2007 | 01:13 PM
allthrotle's Avatar
Ya just a little shocked. I really didnt want to have to flycut. I guess I should have done my homework.
