Dropped a piston, damage assesment
1. Find out what width the top ring groove is from your spec sheet.
2. Find someone who has pin gages this size and slightly smaller/slightly larger than said ring groove width.
3. Measure the ring groove width 360 degrees with the pin gages and see if the area where the bump's located is within .0002"-.0003" of the rest of the groove.
4. If the groove made it through unscathed (unlikely) then just file and scotchbrite the bump.
5. If not I would bite the bullet and get 4 more.
Good Luck
it is a risk to run it imo...
I would be worried about detonation and any internal flaws the fall may have caused as well as the piston being slightly out of round and ring gap colapse (defiantly have a machine shop check it out 110%). see what they say.
but hey, it aint my motor.
you will probably be fine... just.. if you do run it.. be very aware of it.. and if something happens dont be "OMG WTF" lol
Steve
