1st Cam, Got Some Questions
I just bought this cam...
Cam Motion custom grind
Dur @ .050 230 intake and 235 exhaust
Lift 593 intake and 598 exhaust
112 Lobe sep and 108 intake centerline
To go with these heads...
TEA Stage II 5.7l 908 castings, milled 0.050 w/ Comp 1.440” 978 springs 2.02 intake 1.60 exhaust
I bought 908 casting heads without knowing the differences between them and my stock '99 heads. The perimeter bolts don't bother me. I've already purchased '98 valve covers. The issue I have is the notch cut out the bottom. Am I alright with getting stock '98 head gaskets, or do I go to a machine shop to fill in the notch and get '99+ metal gaskets?
Cam Motion said I need to figure out the pushrod length myself. My heads are milled .050, my gaskets will be stock thickness (I think?), and the base circle of the cam is the same as stock (I think?)... then I need 7.350 length pushrods correct? I don't know the stock base circle dimension, but I can get a micrometer to measure it on the new cam if that can make a difference. If somebody could tell me the stock base circle dimension I'd appreciate it.
LS2 timing chain. That's still a good choice, correct?
LS6 oil pump. Porting really necessary?
LS2 chain is good, I spent the extra dough for a ported pump.. I think it's worth it.
Those pushrods sound right.
Would you say this cam would work on stock heads with the correct springs without flycutting?
Porting an oil pump allows for more oil to flow, while shimming allows for more oil pressure
Damn, I did not want to flycut the pistons.
I did not realize I could do that. How will this affect performance?
